I want to create a repository in FME Server 2015 where anyone can run the workspaces.
Can I run a workspace in FME Server without logging in?
Best answer by fmelizard
@arjanvanzutphen
View originalThe fmeguest role provides this sort of unauthenticated access. Each request to FME Server that lacks credentials is first attempted with the guest account. So if the guest account is connected to a role that has permission to use repository 'x', then no credentials will be required. I think the only thing you need to do is give the fmeguest role the read and run policy for your workspace.
A bit more information on the guest account. http://docs.safe.com/fme/html/FME_Server_Documenta...
