Can i use python scripts without importing fmeobjects?
  • September 1, 2015
  • 14 views
Is fmeobjects mandatory while using pythoncaller, or can i run python scripts from pythoncaller transformer without importing fmeobjects?
Best answer by david_r
Hi
You only need to import fmeobjects if you want to manipulate FME features passing through the PythonCaller, or access other FME functions as described in the fmeobjects API: http://docs.safe.com/fme/html/FME_Objects_Python_API/index.html
Is there a particular reason for not wanting to import fmeobjects?
David
  • September 1, 2015
Hi
David
