Can the option to "Save As User Parameter Default Values" be set in a Server App?
bigcl
In the Desktop User Parameters dialog there is the option to "Save As User Parameter Default Values". I have server app and I would really like to use this feature so that the parameter information the user entered is retained for when they run the app again. I haven't been able to find a way to do this - is this possible?
Many thanks 😁
hkingsbury
Forum|alt.badge.img+54
  • January 17, 2024
Unfortunately I don't think you can. Flow will default to the values that were in Form when you published the workbench.
I think it's a great idea however and you should submit it to the Ideas List - https://community.safe.com/s/bridea/acideasULT__brIdea__c/00B4Q00000AWlEVUA1
bigcl
  • January 17, 2024
Many thanks.
I have submitted it to the ideas list 💡
