Can FME server run multiple jobs at same time?
viviancfhung
I found FME server can run a job at a time. Others are in queue.
Can we set FME server to run multiple jobs at same time? such as 2-3 jobs a time?
f.kemminje
Forum|alt.badge.img+11
  • January 10, 2023
one engine one fme workspace.
if you have 8 engines then, you can run 8 workbenches at a time.
Go to settings and check for how many engines.
viviancfhung
  • January 10, 2023
Thanks. Is one engine one license?
f.kemminje
  • January 10, 2023
One engine =one fme instance to run
  • January 10, 2023
Each engine instance needs to be associated with either a standard or a dynamic engine license, see https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/engines.htm
viviancfhung
  • January 12, 2023
Thanks
