Are there known interface flickering issues in FME Form 2023.x
  • October 31, 2023
  • 14 views
mvanwie
Participant
I started building an ETL job in Form 2023.0 that only reads in about 250 PDF files containing 1-3 pages where I need to extract some text. I've recently upgraded to 2023.1 and the issue still persists.
I've noticed after working on the job for a few hours the FME Form UI will randomly start to flicker as if my mouse button was stuck down and was spamming clicks every second. It doesn't trigger a click event and it only happens within FME. If you attempt to work around the issue it rapidly continues to get worse until the screen completely stops updating.
The only solution I have found once this starts is to save your work and restart FME.
I've attempted to attach a video of the issue.
In the video, I only zoom the view once despite it looking like I'm scrolling in and out really fast and I'm only clicking on each transformer or pathway once as well.
Snippet from System Info:
OS Name Microsoft Windows 10 Enterprise
Version 10.0.19045 Build 19045
System Manufacturer Dell Inc.
System Model OptiPlex 5060
System Type x64-based PC
System SKU 085B
Processor Intel(R) Core(TM) i5-8600T CPU @ 2.30GHz, 2304 Mhz, 6 Core(s), 6 Logical Processor(s)
BIOS Version/Date Dell Inc. 1.2.22, 11/1/2018
SMBIOS Version 3.1
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Product 030VXY
BaseBoard Version A01
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.8 GB
Available Physical Memory 5.01 GB
Total Virtual Memory 31.8 GB
Available Virtual Memory 17.6 GB
Page File Space 16.0 GB
  • November 1, 2023
Check if there are any updated video card drivers available for your PC.
