sql creator using fme multichoice string parameter
  • January 28, 2014
  • 21 views
gio
Forum|alt.badge.img+15
Hi all!
I have a parametrizing question.
I use a sql for a dynamic sql creator. This uses paramaters so user has some pickin choices.
This question concerns the in operator:
somecodes in ($setofcodes)
where $setofcodes is a multichoice parameter.
Now, some wise db manager thougth it wise to do
Gytpes (l), (v) etc.  (lines, vlak (wich is dutch for area)) etc.
I turn this into 'l','v' as  the in function needs this : gtypes in ('l','v')
When it concerns numbers, somecode in ($setofcode) works.
When its stringtype it doesnt do anything.
I create setofcodes like this:
regexp_replace(regexp_replace('l/t/v v,mv l v 2p','([a-z0-9/,]+)','''\\1''',1,0,'i'),' ',',',1,0,'i') wich generates 'l/t/v','v,mv','l','v','2p' to use  in the in function:
in my sql it is regexp_replace(regexp_replace($geotypes,'([a-z0-9/,]+)','''\\1''',1,0,'i'),' ',',',1,0,'i')
the bit 'l/t/v v,mv l v 2p' is provided by a myultichoice parameter if one would choose all those that is). This mulitchoice parameter adds a space between choices like 'l v' etc.
I tried concatenation: somecode in '('||$setofcodes||')' Also with triple quotes). No dice.
It seems to fail to see the outer braces needed for the in function.
No error arises, just an empty solution.
the script using the parameter works for integers. Because those dont have quoutes.
And of course it works if i type in the string 'l/t/v v,mv l v 2p' rather then have it generated trough a multichoice parameter.
I can do this
SELECT
        t.id  id,
        t.objectcode objectcode,
        rtrim(regexp_replace(c.GEOTYPE ,'.([0-9a-z,/]+).','\\1',1,0,'i')) geotypes,
        t.inwin  inwin,
        t.nivo  nivo,
        t.geometrie geometrie,
        t.guid      guid,
        c.CLASSIFICATIE
FROM    dgdtw_topografie t,
        class_leiden c
where t.objectcode = c.objectcode
  and t.verval is NULL
  and rtrim(regexp_replace(c.GEOTYPE,'.([0-9a-z,/]+).','\\1',1,0,'i')) in ('l','g')
  and (t.OBJECTCODE in ($objectcodes)
  or $betweens)
  $nivo
  order by t.nivo asc
but if i replace 'l','g' with
(regexp_replace(regexp_replace($geotypes,'([a-z0-9/,]+)','''\\1''',1,0,'i'),' ',',',1,0,'i') with same content, it wont work
also the script work when i limit the gtype choice to just one type and write it like
rtrim(regexp_replace(c.GEOTYPE,'.([0-9a-z,/]+).','\\1',1,0,'i')) = '$geotypes'
($nivo is parameter for level and will either be empty or consist of a piece of sql)
Allt the regexp scripts work in sql creator, no need to test those... ;)
  • January 30, 2014
just a thought: it might be easier to perform this processing in a Python scripted parameter. You can then pass the parameter value into the where clause of your SQLCreator.
Personally, I find this strategy a bit less opaque and easier to debug, as you can develop test cases for you algorithm outside of FME, e.g. using the Python interactive shell or IDLE.
David
gio
  • January 30, 2014
I'll try that out soon.
I did try that using a scripted tcl parameter to generate the sql statement. But when i tried using user parameters in the scrupted one, i got some: using parameter reference out of something something error.
  • January 30, 2014
a couple of potential sources of errors when using scripted parameters like this:
  1. The order of the parameters in the Navigator matters. In a scripted parameter, you cannot reference a parameter further down the list, only those above. Drag and drop to reorganize the order.
  2. I've had some strange errors when using scripted parameters directly into the SQLExecutor. What I did to circumvent this was to create a regular text parameter that references the scripted parameter. You can then reference the "static" text parameter in the SQLExecutor SQL statement.
David
gio
  • January 30, 2014
Thanks for the tips.
the script does work when i use a single choice parameter.
It als works when in case of multichoice, the parameters are integers.
It's the combination of stringvalues and the sql "in" function.
Like:  'A' in ('A','B','C') WHere the latter part is created using a regexp in SQL.\\
(regexp somethingsomething)  I also tried '('||(regexp something)||')' etc.
It seems to me that the outer brackets are not recognized.
The same happens when i do this directly in SQL-creator.
No error message, i just get no result.
I 'll try building the string in a scripted parameter, and take care of the order of parametes.
Let you know if and when i succeed.
Thanks.
BYe,
Gio
