Finding lines that are parallel and at a certain distance from each other
  • March 9, 2023
  • 55 views
arash_hokm
Forum|alt.badge.img+8
Hello FME community,
I have two feature classes with line type. I would like to find the lines in Feature Class 1 that are parallel to other lines in Feature Class 2 at a certain distance.
I calculate the angles of lines and with NeighborFinder I create a list of lines that are near but I don't know how to find the lines that have the same angles to feature class 1 (with about 10 degrees difference).
Forum|alt.badge.img+31
  • March 9, 2023
Have you looked at the custom transformer FuzzyParallelLineFinder?
