Rectifying small overlaps and gaps between polygons
  • June 29, 2023
  • 112 views
I possess a polygon layer containing sections where polygons overlap and also areas where gaps exist between them. My objective is to address only minor overlapping sections, specifically those where polygons overlap by less than 20 square meters. I wish to consolidate the gaps between polygons as well, targeting cases where the gap between boundaries is less than 20 meters. Is it feasible to perform this analysis using FME?
I attempted to utilize the AreaGapAndOverlapCleaner in FME, but it appears to make adjustments for any type of overlap. However, in certain instances, two polygons may possess identical geometry, and I do not desire the overlap to be rectified in such cases.
  • June 29, 2023
With a bit more testing it looks like the Snapper tool does the job
