The water utilities meter site addresses are in our billing system. This information is daily pulled into a MS SQL server table. I would like to use FME to take the MS SQL table address information and load this table into four feature classes that are in a dataset in a versioned water geometric network .sde database. This .sde database is reconciled and posted nightly. I have worked with versioning and how to best accomplish this. Any suggestions are welcome.
I work for a water utility which has addresses in a billing system and load them into GIS feature classes in a dataset in versioned geometric network .sde database.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
