Not getting datadownload link within email body
f.kemminje
Forum|alt.badge.img+11
Hi Fmeirs,
I am not getting datadownload link inside the body of my email. I created a topic and subscription. and everything is configured. and working fine.I used fmeservernotifier inside fmw. And running from fme server. I am getting all plain text and the pulished parameters (variables) as email, But not datadownload url. Can anyone help me where i am going wrong?
i attached sample fme script.
fgiron
Forum|alt.badge.img+20
  • April 10, 2019
I think the problem might be the set-up of the Download Service. You have to set which writers are being included in the download in the service properties while publishing your workspace:
Beside that, you're using FME 2018.1.1 and in that version the Download Service couldn't use output data from FeatureWriters. This has been solved in FME 2019: https://knowledge.safe.com/idea/41306/use-featurewriter-output-for-datadownload-service.html
fgiron
  • April 10, 2019
Have a look as well at this question, it might help https://knowledge.safe.com/questions/68502/fme-server-featurewriter-transformer-role-in-data.html
f.kemminje
  • April 11, 2019
@david_r , @takashi Hi Takashi / David,
can you please help me on this?
