ESRI FGDB reader
I am having massive problem in the time taken for a workbench to read an FGDB.
Is there a way (or a different reader) which can speed this up? It's laughably slow at the moment and completely unusable and this is before I've even done anything with a clipper transformer.
  • August 16, 2019
Is the file geodatabase located on a local drive, or on a network drive? That can have a huge impact on performance.
It's on a Network Drive. I'll test on a local drive and see if it is different.
It's just as slow on Network and Local Drive.
