Server - schedule placing files in wrong folders
Hello all,
I have an incredibly weird issue....
Running the workspace from FME Desktop, and running manually via Server there is no issues at all. When the workspace runs via a schedule nightly it is writing files into different folders...
FME Desktop and Manual Server run - \\\\server\\folder\\folder\\folder 1
On server via a schedule - \\\\server\\folder\\folder\\folder 2
I have deleted the schedule and added a new one but the same issue occurs, and it is only for this workspace.
Any ideas..?
Forum|alt.badge.img+48
Have you compared log files from both runs? Are you running the workspace with the same permissions both times?
rylanatsafe
Forum|alt.badge.img+13
Hi @mswards - If you can share a few more details, it will help the FME community help you! Please reply to this thread and provide additional details including:
  • The version of FME you are using, including build number
  • Your FME workspace
  • Your FME Desktop and Server translation log files
  • Screenshots or details about the Schedule you have setup
  • Any other information that may be useful to share
