I wonder how i can merge an excelfile with several sheets to an shapefile. The shapefile has the location of stations and in the excelfile I have information aout the stations for each station. i.e each station has its own sheet.
I really would lika som help with how i can merge this, please.
If there's a common ID between the Excel data and the shape feautures, the most obvious choice would be to use a FeatureMerger.
If you configure the Excel reader to read the entire Excel file as a single merged feature type, the "fme_feature_type" attribute will contain the sheet name, which you could reference in the FeatureMerger:
