Name Workspace output File like the RasterTIler output tile number.
  • December 12, 2020
  • 6 views
I tiled a raster image with the RasterTiler and get as result 4 tiles and now I want to name the workspace output file like the output tile numbers.
Like this:
up left tile= 1 -> Filename_1.TIF
up right tile=2 ->Filename_2.TIF
bottom left tile=3 -> Filename_3.TIF
bottom right tile= 4 -> Filename_4.TIF
So I used the stringconcetonator to name the attributes like the tile numbers, but I dont get the desired result what am I doing wrong? Best Wishes Tina
StringConcetonatorRasterTiler
caracadrian
Forum|alt.badge.img+23
  • December 14, 2020
Use a Sorter by _tile_row and _tile_column (in that order in the same Sorter) than a Counter to create your file index.
