Rounding the elements of a list
Hello,
I have a list of numbers and I wanna round all its elements to a precision.
How it can be done in FME ?
Thank you very much in advance.
Best answer by itay
The easy way would be to explode the list (ListExploder) and round the values using the AttributeRounder and then recreating the list (ListBuilder).
Hope this helps.
itay
Forum|alt.badge.img+17
  • May 31, 2018
Hope this helps.
jdh
Forum|alt.badge.img+28
  • May 31, 2018
Itay gives the easiesy way, but consider voting on https://knowledge.safe.com/idea/24729/attribute-manipulation-on-lists.html (with a comment to add AttributeRounder)
itay wrote:
Hope this helps.
It worked
Thank you very much
