Transformer development
  • November 20, 2013
  • 7 views
I would like to use a computation algorithm written in Java to implement a transformer using the Java FME Plug-in SDK.
Unluckily the documentation for the FME Plug-in SDK is not very complete and contains no Java transformer example just a C++ transformer exemple.
Where I can found more documentation and samples? (specially on how configure the .fmx metadata file for my transformer)
Thanks,
Luca
Forum|alt.badge.img+19
  • November 21, 2013
Hi Luca,
As far as I know, there are no documentation other than files in "(FME_HOME)\\pluginbuilder" folder on your machine. About fmx,  you can see the configuration of existing transformers as examples.  (FME_HOME)\\transformers\\fmesuite.fmx   I remember that old version "fmesuite.fmx" included some descriptions, but I cannot find them in the current version (FME 2013 SP4). Maybe you had better contact Safe, if you need more detailed information...
Takashi
  • November 22, 2013
Hi Takashi,
Thank for the tip, effeclty I founded a fmesuite.fmx containing some descriptions on an old installation (FME 2008).
Luca
