Hi FMErs
Is there a way to extract the bottom-left coordinates from an output geometry using the Tiler transformer?
The reason is that I'm tiling/filing a geometry (to CAD format) and would like to use the bottom-left coordinates as file names, like for example "x=12000 - y=3000.dwg".
Please let me know if you need me to elaborate or if it is not clear.
Many thanks
