FME Server: Allow user to upload own data?
bjudes
Forum|alt.badge.img+10
I am creating a workbench to be uploaded to FME Server. As part of the workbench I want the user to be able to upload their own shapefile (Any shapefile, no restrictions.). How do I setup the user parameters to allow this to happen?
Thanks for any help.
B
  • August 16, 2018
bjudes
  • August 16, 2018
david_r wrote:
I had a look at this article/tutorial but when I go to run the workspace I get an error -
During translation, some features were read that did not match a reader feature type in the workspace. This can happen if the reader dataset is changed, or a reader feature type removed or renamed.
The workspace will only successfully run if I use the exact data set specified when the initial reader was created?
  • August 16, 2018
If the uploaded dataset won't necessarily match the dataset you used for development, you should probably switch to a dynamic reader.
The first thing to try would be to recreate the reader as a singled merged feature type:
bjudes
  • August 16, 2018
That was the problem, very good. Thanks for the help.
