How to read the symbology related attributes from a CAD File
  • September 18, 2017
  • 5 replies
  • 26 views
I want to read the following attributes related to symbology from a CAD file and want to store it in Single Attribute by using Json Packer and want to store it into File Geodatabase.
  • Color: Color
  • Template: Template File Source
  • Blocks–> Block Name, Block Rotation, Block Size By, X, Y, Z
  • Lines–> Line Type, Line Type Generation, Line weight, Line Scale, Line Elevation,
  • Area–> Area Entity Type, Fill Pattern Name (if Gradient), Pattern Scale, Gradient Name, Gradient Fill Color 1, Fill Color 2, Fill angle, Fill Origin x, Fill Origin Y.
  • Text–>Text Entity Type, True Type Font Name, Text Shape Name, Text Justification, Text Size, Text Rotation, Text.
I also want to use these attributes by unpacking it in DWG Styler in some another workflow.
Can help in this?
Thanks in advance. Appreciate your quick support.
Please explain the way to expose all the attributes related to symbology or any other method to store the symbology?
or
Please tell the names of corresponding attribute names for e.g
Block Name --> autocad_blockname
Block Rotation--> ?
Block Size By --> ?
X, Y, Z --> ?
Area Entity Type --> ?
Text Entity Type --> ?
Others i am able to find corresponding attributes..
pratap
Forum|alt.badge.img+12
Either you can use attribute exposer or enable the attribites in format attributes in reader
Block Rotation--> autocad_rotation
Block Size By --> autocad_xscale. autocad_yscale, autocad_zscale
X, Y, Z --> autocad_block_insert_x, autocad_block_insert_y, autocad_block_insert_z
Area Entity Type --> autocad_entity
Text Entity Type --> I did not understand what does this mean
danilo_fme
Forum|alt.badge.img+52
  • September 19, 2017
Hi @dheeraj,
Has a interesting link that demonstrate getting format attributs from DWG, very interesting Tutorial.
Thanks,
Danilo
danilo_fme
Perfect description @pratap
gabriel_hirsch
For the text entity type attributes:
autocad_draw_direction
autocad_font_bold
autocad_font_charset
autocad_font_italic
autocad_font_typeface
autocad_shape_filename
autocad_shape_name
autocad_text_size
