Extract from GML file building height and area?
  • March 30, 2020
  • 20 views
Hello there, I am a bit new here. Thus this might a bit of a simple question, but I'd really appreciate it if you could point me in the right direction.
I have a GML file from which I only need the heigh and area of the buildings. I'm trying to use the interpretability tool from ArcGIS pro. But somehow the transformation is not working properly. Any idea what transformations I need in order to extract to a shapefile/database the info I need?
oscard
Forum|alt.badge.img+21
  • March 30, 2020
If you drag and drop your GML file into FME Workbench, the proper Reader appears. FME should be capable of reading each attribute of the GML.
Then you just have to add the Writer you want and keep only your desired attributes.
