Hello folks
I trying to find away to convert ArcMAP text to AutoCAD Multi-line text. Is this possible with FME?
Yes. I think you'll need to take a look at utilising the AutoCAD format attributes such as:
autocad_mtext_string
autocad_mtext_text_height
etc
Take a look at the FME Readers and Writers manual here... Autodesk AutoCAD DWG/DXF Reader/Writer > Feature Representation > Multi-Text Entities.
http://fmepedia.safe.com/articles/Documentation_del/FME-Readers-and-Writers
http://fmepedia.safe.com/articles/FAQ/What-s-the-difference-between-user-attributes-and-format-attributes
http://fmepedia.safe.com/articles/How_To/How-Do-I-Set-a-Format-Attribute
As long as FME-Talk stays readable look here for some lengthy discussion on MTEXT.
https://groups.google.com/forum/?fromgroups=#!searchin/fmetalk/MTEXT/fmetalk/RYhE3JJrg-A/0njVHqB7JhoJ
Some quoting from there ...
In order to get Bold or Italic styled True Type Fonts, it is necessary
to fill the attribute "autocad_mtext_string" with something like:
{\\fArial|b1|i1|c0|p34;Text}
where
b1 ... is the flag for bold and
i1 ... is the flag for italic
Michael
