Combine raster backdrop + point features to raster tile set
  • February 4, 2014
  • 13 views
I have a set of raster tiles as .tif and accompanying .tab files, and a set of points (building numbers) which I want to superimpose on top of the raster layer, these are in .shp format.
I want to combine both these layers to produce a set of raster tiles showing both – i.e. the original raster tiles as backdrop, the building numbers on top.
I know FME can do this, I just don’t know how and my ‘experiments’ have not proved successful – could someone please point me in the right direction?
Thanks, Sue
Best answer by owen
Hi Sue,
You could use the text stroker and vectoronrasteroverlayer. Or, if you have FME 2014 the mapnkrasteriser will do it all for you, with a lot of great styling options.
Owen
owen
  • February 4, 2014
Hi Sue,
Owen
