Setting a random colour per group - is there a better way?
  • July 5, 2013
  • 97 views
Forum|alt.badge.img+31
I want to set feature colours at random according to an attribute value (similar to a thematic map).
At the moment I'm achieving this by taking the data, using a duplicateremover so there is one instance of each group, a featurecoloursetter with the color scheme set to random, an attributekeeper to keep only the group attribute and the colour and then a featuremerger to merge the data back with the original data so that all features that share a certain attribute value have the same colour.
It seems a bit long winded and I'm wondering if  I've missed a better way to acheive this.
Best answer by takashi
How about the following trick?
Takashi
Forum|alt.badge.img+19
  • July 5, 2013
Takashi
