Problem with Access in FME after Office365 migration
  • January 23, 2018
  • 6 replies
  • 114 views
After a migration to Office365, FME is unable to open Access files. The following error is given:
Microsoft Access Reader: Unable to find provider 'Microsoft.ACE.OLEDB.12.0', falling back to 'Microsoft.Jet.OLEDB.4.0'. The 2007 Office System Driver might be missing from your system; follow this link for more information: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id;=23734
Microsoft Access Reader: Connection failed. Connection string `Provider=Microsoft.Jet.OLEDB.4.0;Jet OLEDB:Engine Type=5;Data Source=K:\\dienst VR\\02_rapporten\\Lijst_SEVESO-inrichtingen 2016.accdb;User ID=admin;Password='. Provider error `(-2147467259) Onbekende database-indeling K:\\dienst VR\\02_rapporten\\Lijst_SEVESO-inrichtingen 2016.accdb.'
We tried installing 2007 Office System Driver, as given via the link in the error message, but this did not solve te issue. The following error message still appears:
Microsoft Access Reader: Connection failed. Connection string `Provider=Microsoft.ACE.OLEDB.12.0;Jet OLEDB:Engine Type=5;Data Source=K:/dienst VR/02_rapporten/Lijst_SEVESO-inrichtingen 2016.accdb;User ID=admin;Password='. Provider error `(-2147467259) Unrecognized database format 'K:\\dienst VR\\02_rapporten\\Lijst_SEVESO-inrichtingen 2016.accdb'.'
Does anyone know how to deal with this issue? Thank you!
Bert
fmelizard
Forum|alt.badge.img+18
  • January 23, 2018
Hi @bakkermans, are FME and Office365 the same bit version?
  • January 26, 2018
Hi @TiaAtSafe They are, both are 32bit.
Access Office 365 2016 32bit (b 16.0.8201.2200)
FME 2016.1 32bit (b 20160419)
  • January 31, 2018
Anyone any advice? I'm a bit out of ideas here on how to solve this..
debbiatsafe
Forum|alt.badge.img+20
  • February 19, 2018
Posting the solution found in case it may help another user with the same issue. If you are using Office365 and is running into the same error, please go to the following link:
https://www.microsoft.com/en-us/download/details.aspx?id=39358
Download and install the appropriate bit-version of Access 2013 runtime installation package (the bit-version should match your FME installation).
At the time of this comment, Microsoft has not released an installation package for Access 2016 runtime that is compatible with Office 365. According to this Microsoft forum thread, Access 2013 runtime installation is functionally equivalent and should resolve the error.
Edit: this driver may also work but has not been tested https://www.microsoft.com/en-ca/download/details.aspx?id=54920
Hope this helps,
Debbi
spatialcase
  • June 25, 2020
The second link (id=54920 2016 runtime) did not work for me but the first link (id=39358 2013 runtime) does work. I am using FME 2019.2 32 bit with Office 365 32 bit.
mattwilkie
Forum|alt.badge.img+11
  • January 6, 2025
Installing the 2016 Access Runtime solved the problem of this warning polluting our logfiles with extra noise. (FME would try Microsoft.ACE.OLEDB.16.0 then fallback to Microsoft.ACE.OLEDB.15 and then to… until it finally found a version number that worked. )
I thought there was an idea somewhere about adding a parameter to the reader select the version number to start with but I’m not finding it today, so adding this note here so it’s found the next time we search for this message there’s something to follow. ; -)
