How to convert CityGML to Cesium 3D tiles with double side facing?
  • November 5, 2018
  • 16 views
Dear all experts,
I am now dealing with the project that visualizes CityGML on the Cesium web application.
My input CityGMLs sometimes have a wrong orientation so that the output 3D tile have the wrong side of the wall. Is there a way to convert with double side facing or to correct the wall orientation?
Thank you so much!
Best regards,
Joe
virtualcitymatt
Forum|alt.badge.img+35
Hi @joeac123, I think the GeometryValidator should sort it out. Set the set of issues to fix to be Solids and Surfaces. Make sure you are setting the Attempt repair to yes. The repaired and passed should then be connected up to your output workflow.
