Is it possible to export the FME Server schedule? I have looked through multiple FME Server folders, but have not found a file with the schedule. Adding such a feature could be beneficial. Thanks.
Export Schedule
Best answer by erik_jan
The schedule is stored in the (default postgres) database. With the FME postgres reader it is possible to export the schedule and write the information to for example Excel or any other (non-spatial) format.
