Hello everyone
I would like to know if with a dgn V8, it is possible to create space model centered on the rights of the main file
At the same time that the file dgn is created
thank you
Hi @cprhamel,
Could you share us more detalis about this case?
Thanks,
Danilo
@cprhamel, has a link about space model in DWG
Layouts
Thanks,
Danilo
The solution for dwg me goes
I have a dwg file with in the multiple zone model
And for formatting the presentation
I would like to create layouts centered on each zone
To display a legend, a cartridge ...thanks
Coul you share a sample data?
Hi @cprhamel
when you write a dgn-file, models are copied from your seed-file, i.e. you would need to have a model 'centered on the right of the main file' predefined in your seed-file. If you need to define models dynamically, would you mind posting an idea?
