Hi
Just wondering if anyone knows if this is possible?
I'm not sure what kind of data the "aerials" is ... If it is 3D points or lines, try using the ContourGenerator transformer.
Takashi
If you are refering to rasters (form previous post) the the rastertopolygoncoercer might be what you are looking for, otherwise a better description of  'contours' can be helpful
Yes it is, whether it be raster or geometries.
There are a coupe of examples roaming in the knowledge base.
