LAS writer: Failed to obtain point cloud from feature. Only features with point cloud geometry are expected
LAS writer: An error has occurred. Check the logfile above for details
Help. I’m receiving the two lines of error shown above ^
I am trying to modify a folder of .LAS data to create a TIN based on a certain classification (Ground).
I don’t understand why I’m receiving these error codes if all of the other items are running and previewing successfully.
