I have a feature class with cycling and walking routes (with ID and Name) and a feature class with the starting points of the (circular) routes. I want to write all the routes in the feature class to separate gpx-files. Each gpx-file should have the name of the route in its filename.
I tried with the ‘fanout’ option in the writer, but the resulting files are no gpx-files and are very small (1kB), so without content I guess.
Any advise?
