Hi. reading LYRX (“layer files”) from ArcGIS Pro failes when the layer file include Grouped Layers. It works just fine if the LYRX file does not include Group Layers.
Thea Layer File/LYRX is made with ArcGIS Pro 3.2.2 where the LYRX file is in JSON format.
Forgot the demo dataset. A Shapefile which is put into a group +sub-group layer.
Zip file
Hi @palhermans
I was able to reproduce this issue so I have filed a bug report oInternal - 82653].
I apologize for any inconvenience. We will make sure to keep you updated.
Crystal
Thanks for the very quick response @crystalatsafe
pH
Hi @palhermans
After checking in with our team, this is a significant enhancement and requires additional motivation.
Therefore, I have created an idea for this and kindly request your feedback in the comments section. Hearing about how this affects our customers' workflows and use cases helps our team better prioritize enhancements like these in the product.
Thank you!
Crystal
