I would like to pass date/time user parameter (Date Ranges) to a SQL-Non Spatial reader where clause
  • June 20, 2019
  • 44 views
keitho
Forum|alt.badge.img+3
Hello,
I would like to pass date/time user parameter (Date Ranges) to a SQL-Non Spatial reader where clause. I have tried the following with no success.
[wo_complete_dt]>= {ts $(DateRangeStart)} AND [wo_complete_dt]< {ts $(DateRangeEnd)}
[wo_complete_dt]>= {ts ‘$(DateRangeStart)’} AND [wo_complete_dt]< {ts ‘$(DateRangeEnd)’}
[wo_complete_dt]>= '$(DateRangeStart)' AND [wo_complete_dt]<'$(DateRangeEnd)'
[wo_complete_dt]>= $(DateRangeStart) AND [wo_complete_dt]< $(DateRangeEnd)
However, if I change the user parameter to a text type or input the dates directly into the Where clause as shown here it does work.
[wo_complete_dt]>={ts '2019-06-09 00:00:00'} AND [wo_complete_dt]<{ts '2019-06-16 00:00:00'}
Can someone please guide me?
Using FME Desktop 2019.
Thanks in advance,
Keith
Forum|alt.badge.img+31
  • June 21, 2019
The date/time user parameter stores the date in FME format, i.e. 20190609000000, although it is displayed as 2019-06-09 00:00:00
You will need to convert the date to the format you need for your sql statement. This can be done in the statement itself.
