Add bounds in projection definition
  • September 22, 2014
  • 7 views
Hi!
I wonder if it's possible to add some bounds to a projection definition in FME in order to set the bounds automatically when the projection is selected.
Thank you for your help!
zoe
  • July 14, 2016
Yes, I'm also interested. Is there anyone answer this?
@burton449 If features fall outside the bounds or straddle the bounds what would you expect outcome to be?
Hi @burton449
are you talking about MapInfo projection definitions by any chance?
zoe
  • August 2, 2016
lenaatsafe wrote:
Hi @burton449
Yes, it is about MapInfo. For example, the output projection has been set as MGA GDA 94 [EPSG: 28355] in FME, which is the same projection required. But the table coordinate System Bounds need to be reset in MapInfo.
I'm wondering is there a transform in FME to set bounds and process automatically.
