Why geometry of geopackage change from 3d to 2d?
abdullah83
Forum|alt.badge.img+5
I am trying to map a geopackage file to another geopackage file (same format). Why is the geometry in the reader I input in 3D format, but the geometry produced by the writer is only in 2D format? Please help.
Do you have the Z value parameter on the writer set to “required?”
abdullah83
  • October 31, 2023
tqvm u are the best.@ericurbistic​ . tqvm problem solve... one more quaestion what is M value?
abdullah83
  • October 31, 2023
I'm actually mapping IFC files to a Geopackage... I successfully mapped the IFC file to a shapefile, and when I tried to map it to a Geopackage using the same design, the geometry didn't get transferred to the Geopackage. Only when I selected the dynamic option, it was successfully mapped... The problem is, I don't want to use dynamic so that I can change the feature's name.
