When connecting to an ArcGIS Portal, the connection only shows item owned by the user or shared with groups. Item that are shared to the organization but not to a group cannot be seen
Thanks for your fast response and good to know this enhancement is coming.
I was aware of the ID workaround but it does not work for me when I use the id of an item shared to the organization. I get the error below
ArcGIS Portal Feature Service Reader: Could not find a Feature Service item matching the Feature Service directive 'example@somewhere.com/09c34d31bf3c4e2cac3cffc9631dded3'
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
