I try to group the polygon
Forum|alt.badge.img+5
I am. try to group all CellValue as you can see I am getting 4881593 records so I need group them please find the workspace
Best answer by dustin
You can use the Dissolver after the RasterCellCoercer, with the group by set to _band{0}.value
dustin
Forum|alt.badge.img+31
  • July 26, 2022
  • July 26, 2022
are they give me polygon ??
dustin
  • July 26, 2022
Ahh, you wanted to group the points instead of polygons. In that case, use the Aggregator instead of the Dissolver, and group by the same attribute. In your RasterCellCoercer, you will need to change the Output Cell Geometry from polygon to point.
  • July 26, 2022
No i want in polygon not points
dustin
  • July 26, 2022
Ok, so yes the Dissolver will dissolve the boundaries between like polygons, essentially grouping them. If you want to retain all the boundaries of the polygons, you could use the Aggregator.
  • July 26, 2022
i done as you said but its taking to much time to load data Screenshot 2022-07-27 at 12.18.45 AM
dustin
  • July 26, 2022
Make sure 'Enable Feature Caching' is unchecked. Having this checked can drastically increase processing time.image
  • July 26, 2022
i did but same result its take 30 mins to run the workspace and the around 45 mins to load the datat
