Why can't FME data inspector read my Locusview gdb dataset?
  • August 26, 2021
  • 20 views
I have a gdb (ESRI) dataset from Locusview which QGIS can read fine but FME Data Inspector (2019) says there is a file missing, but doesn't say which.  The key part of the errors seems to be:
"2021-08-26 05:19:36.616 ERROR - Geodatabase Error (-2147024894): The system cannot find the file specified."
Log reads as follows:
2021-08-26 05:19:20.981 INFO - FME Data Inspector is starting up...
2021-08-26 05:19:29.189 INFO - Loaded module 'fmeprompter' from file 'fmeprompter.dll'
2021-08-26 05:19:36.204 INFO - Creating reader for format: Esri Geodatabase (File Geodb Open API)
2021-08-26 05:19:36.278 INFO - Trying to find a DYNAMIC plugin for reader named `FILEGDB'
2021-08-26 05:19:36.279 WARN - FME Configuration: Maximum of 2000000 feature(s) will be read starting from feature number 1
2021-08-26 05:19:36.613 INFO - Loaded module 'FILEGDB' from file 'C:\\apps\\FME2019\\plugins/FILEGDB.dll'
2021-08-26 05:19:36.614 INFO - FME API version of module 'FILEGDB' matches current internal version (3.8 20190820)
2021-08-26 05:19:36.615 INFO - The feature cache has not been loaded while a new setConstraints was performed. Now loading...
2021-08-26 05:19:36.616 ERROR - Could not open File Geodatabase dataset `D:\\working_folders\\NeilPawson\\Matt_GIS_Test.gdb' for reading
2021-08-26 05:19:36.616 ERROR - A fatal error has occurred. Check the logfile above for details
  • August 26, 2021
@neilpawson​ Try using the Esri Geodatabase (File Geodb) reader instead of the File Geodb Open API reader. That might help trace the source of the problem. If this doesn't work you'll probably have to send your File Geodb to you local FME support provider.
