I need to run approx 10K zipped LAS ASPRS files and generate an xyz file with 5 m grid using ground values. Looking for a workflow to do this.
  • November 24, 2022
  • 23 views
caracadrian
Forum|alt.badge.img+23
  • November 25, 2022
Are your LAS files already classified? Do you have enough memory/disk space on your computer?
You can read LAS files directly from zip then use PointCloudFilter to filter on ground (classification=2) and send to PointCloudCombiner (or skip it, i'll explain).
To get the 5m grid send everything to a SurfaceModeller with DEM 5m spacing and send the output of DEMPoints port to a PointCloudCombiner (you can skip the previous Combiner as it is redundant).
Just write as Point Cloud XYZ and your done.
It is advised to generate a Hull of you data: pointcloud to PointCloudToPointCoercer -> some multipoint option, HullAccumulator (Concave and 10m alpha value) and use the hull to clip DEMPoints output.
Keep in mind that this operation will be very memory and disk intensive!
  • November 25, 2022
LAS files are classified and resources are not an issue.
I read the LAS from zip (962258 pts) and limited to ground (2) via PointCloudFilter (or PointCloudSplitter).
I ran the ground points from the PointCloudFilter to PointCloudPropertyExtractor to extract xyz and then to PointCloudCoercer which results in 327,070 points.
I ran the LAS into a HullAccumulator (Concave, Alpha=10) and to a Clipper and the PointCloudCoercer to the clippee and got 327,070 inside pts as expected.
I sent the inside pts to SurfaceModeller with a 5m grid and wrote out 28,056 DEMPoints to a CSV writer. All I got out were the _elevation values. I want x y z values in a 5 m tab delimited grid. Adding a CoordinateExtractor before the writer appears to have solved the issue.
caracadrian
  • November 28, 2022
Use https://docs.safe.com/fme/2021.2/html/FME_Desktop_Documentation/FME_ReadersWriters/pointcloudxyz/pointcloudxyz.htm Point Cloud XYZ Writer
