Is it possible to transform .gdb files into .ifc files. If yes, what transformers do you use? Sincerely Thomas
  • October 29, 2021
  • 46 views
rahulsharma
Forum|alt.badge.img+10
  • October 29, 2021
Hi @thomasjohnsen82​
You should be able to do this after completing BIM Tutorial At the end of the tutorials is writing examples.
Writing to IFC
AutoCAD to IFC
This example demonstrates how to convert 2D rooms from an AutoCAD floorplan to Spaces in IFC.
Updating IFC
This example demonstrates how to convert an existing IFC file back to IFC, while updating some of the Space property sets from an Excel table.
