I'm doing some geometry checks on an ESRI file geodatabase. The workspace worked fine until I got to a particularly large dataset. Now it runs for a long while and then quits with a popup window saying fme.exe has stopped. I don't know if the subject line, which comes from the log file has anything to do with it but I wondered if anyone might be able to explain what it means.
Thanks,
Alan
