How to map FMEDataReader GEOMETRY column to another GEOMETRY column name in FMEDataWriter using FMEObjectsDotnet4.dll
  • January 13, 2023
  • 7 views
sebastianolaf
Hi FME team
I started on using FMEObjectsDotNet4.dll and started reading CHM help
and I started to write some simple code, and I'm stuck on mapping FMEReader GEOMETRY column to another GEOMETRY column in FMEWriter
FMEReader is from shapefile
but the target database oracle table has 2 columns and I want to directly update to 2nd column, and seems cannot find the right "keyword" in CHM help, also the samples is not really helping with this problem
C:\\Program Files\\FME\\fmeobjects\\dotnet\\apidoc\\FMEObjectsDotNet4.chm
C:\\Program Files\\FME\\FMEObjectsDotNet4.dll
Also in IFMEOWriter seems lacking IsOpen method
to check whether the connection still open or not
so we can do something about it. Maybe like manually commit ..
on another topic:
1) is there a NUGET feed from you for this library
like Telerik nuget feed
https://docs.telerik.com/devtools/maui/get-started/install-nuget
https://nuget.telerik.com/v3/index.json
2) is there a link/resource/forum/video/training/repository
for those interested only in FMEObject in C# only
Thank you in advance!
daveatsafe
Forum|alt.badge.img+19
  • January 13, 2023
Hi @sebastianolaf​,
The reader will interpret the source data and return features containing the attributes and geometry in a standard FME feature object. This object can be written directly to the writer, which will convert it to the necessary structure for the output format.
A pseudocode template for a simple conversion process would be:
create reader
create writer
open reader
open writer
create new feature
while reader.readSchema(feature) == true
    writer.addSchema(feature)
    create new feature
create new feature
while reader.read(feature) == true
    writer.write(feature)
    create new feature
close reader
close writer
The schema defines the table attribute structure and geometry type, and must be written before any of the data features.
However, we have been de-emphasizing the full use of FME Objects and recommend setting up your conversion process within FME Workbench, since this is faster and easier to create and maintain. You can silently run the finished workspace in your .NET application using the FME Objects IFMEOWorkspaceRunner interface.
