Raster boundary to polygon
  • October 26, 2021
  • 5 replies
  • 382 views
fikusas
Forum|alt.badge.img+5
How can I convert raster boundary to polygon? Raster Domain is equivalent tool in ArcGIS / Pro.
Raster Boundary to Polygon
Best answer by virtualcitymatt
fikusas wrote:
Is this the only way? Because there will be a lot of small polygons made by RasterCellCoercer. It requires quiet much proccesing power and time (depends on raster obviously).
Try using the RasterExtentsCoercer. You can choose to extract the data extents. As long as teh area outside the polygon is nodata or (maybe even) masked with an alpha band this should give you what you want.
If this doesn't work you might have to preprocess the raster to make sure the are outside the polygon is set to NoData
  • October 26, 2021
You can use a RasterCellCoercer with output set to polygons and excluding nodata, and then pass the individual cell polygon to a Dissolver. The output of the Area port should be what you're looking for.
fikusas
  • October 26, 2021
virtualcitymatt
Forum|alt.badge.img+34
  • October 26, 2021
If the raster is huge, I agree. The RasterCellCoercer can be painfully slow.
Looking a bit further (thanks @d_l​ !) I see there is a RasterExtentsCoercer that should do what you want. Set it to Data Extents to exclude nodata values.
virtualcitymatt
Ok, so I did a quick test. This only works if the area outside is NoData (an alpha band is not treated as no data.
If you have an Alpha mask then you can use a RasterBandSelector (select band '3'), RasterBandKeeper (this keeps just the Alpha band), then use a RasterBandNoDataSetter and select '0' for the NoData value. The RasterExtentsCoercer will then work well. I Tested this by clipping out the middle of a PNG file.
