FME Desktop 2020: How to concatenate based on a particular field when working with “AreaOnAreaOvelay” tool?
jamal
Forum|alt.badge.img+5
When performing the “AreaOnAreaOvelay” tool, I wanted to create a field at which the values of the “autocad_color” field are concatenated as per the screenshot below.
How this can be accomplished?
Clip_1233
Clip_1234
Clip_1235
Clip_1236
Best answer by virtualcitymatt
You should use the "Generate List" checkbox and then add in autocad_color - Here for each overlap you will get a list containing the autocad_color's. to create a single attribute comma separated you can use a ListConcatenator on the list.
virtualcitymatt
Forum|alt.badge.img+34
  • November 26, 2021
jamal
  • November 26, 2021
Thank you for the help. It works fine
Clip_1238
Clip_1239
