I have a feature that is a circle and stored in Oracle. When translating it to a MapInfo Tab writer, the circle does no export to a circle it is more of a 12+ sided polygon and slightly shifted.
Is there a way to rectify this issue? or even assign tolerances? I have read somewhere that it relates to the number of bits - the FME version I have is 64 bit and the writer output for MapInfo TAB is 20 bit?
Hi @matkins
FME is converting the circle to a polygon. I think you'll need to force the geometry type for TAB using the format attribute mapinfo_type and set it to value mapinfo_ellipse
I tested using a GeometryFilter to find the Circles, then create the attribute with an AttributeCreator
The bit version of FME isn't going to be the issue.
Hi @matkins
Hi @matkins did you get this working?
Hi @mark_1spatial,
I ended up inputting the min/mas x and y parameter bounds and it resulted in a much better rounded circle.
Thank you for your help!
