When I am translating Smallworld 4.2 using a seed file that has a coordinate system set the file that is created does not have a coordinate system set. If I create a file from within Microstation using the same seed file the new file does have the coordinate system set. I verified that during the translation using FME the correct Seed file is being used. I then created a translation of a V8i Microstation file translating to another V8i Microstation file using the same Seed File and the coordinate system is unset in the created file.
Am I missing some kind of setting? or is there a know problem with Coordinate systems and Microstation files?
