Geotiff boundries
  • October 9, 2018
  • 36 views
Hey all,
I'm just recently working with FME. We are using fme for converting xyz pointclouds to geotiff format. Converting is not longer a problem (thanks to the fast help here).
But now i'm looking how i can set a boundrie for the geotiff. (drawn in blue)
As you will see in picture i have added here the geotiff also gives elevation where there is no data. (blue circle).
I know that in C3D i can set a boundrie for the geotiff or give a max triangle length(witch is not the best solution but also works for this problem). Is there anything like that possible in FME?
Many thanks,
Koen
Best answer by takashi
Hi @venkenk, I suppose that you created the raster with the RasterDEMGenerator.
If you create another raster with the NumericRasterizer (Fill Background with Nodata: Yes) from the same point cloud, you can convert it to a polygon representing the data area with the RasterExtentsCoercer (Extents Type: Data Extents). You can then clip the current DEM raster by the polygon to get rid of the unnecessary part.
Note: Depending on the data condition and parameters setting in the NumericRasterizer, the RasterExtentsCoercer could create an aggregate (multi-part polygon) or a donut (having holes). Maybe you will have to determine the parameters in the NumericRasterizer with trial and error and/or use some additional transformers such as DonutHoleExtractor in order to clean the polygon up.
  • October 9, 2018
