The FME workbench fails to preserve the default values of the fields of the attribute table of geodatabase feature class (converting from file gdb to file gdb),
  • September 9, 2015
  • 14 views
lubna_najeh
Hi All,
I tried to sort fields “F1 & F2” of file geodatabase “T1” and each field has a default value, the fields are sorted “F2 then F1” but the default values are not preserved in the result file geodatabase “T2”.
What might be the issue here?
Best,
Lubna
  • January 5, 2016
I think the default value is something that is set in the geodatabase data model and FME does not bring across the entire Geodb data model by default. To do this you need to use a geodb template file on the FME Geodatabase writer. See the article on using geodatabase template files
