Trouble reading Excel files into my workbench
Hello,
I am struggling with reading Excel files into my workbench.
I built my workbench based on an Excel file with this format.
When adding the reader I set the 'field names row' at 3, so the names in row 3 are used as column headers in FME.
I want to use my workbench for other files as well. These files have the same format. Only the information from row 4 will be different. So I created two user parameters witin my workbench:
- Input File
- Output Directory
If I open my workbench and run the translation I can fill in the user parameters:
When I choose the original file which I used to create the workbench, all goes well.
But when I choose another file, I only get missing values:
I even made a copy of the original file, so it is exactly the same document with only a different file name. But even then I get missing values.
Can anyone explain to me what I need to change in my settings to overcome this?
Has the red indication in the User Parameters window something to do with it?
Thanks in advance!
Eva
Best answer by chrisatsafe
Hi @eva218,
Have you tried setting the Additional File Settings to Use Current Settings instead of Use FME Default Settings?
https://www.screencast.com/t/AAUjXryI
  • April 27, 2020
Eva,
if u can attach your xls file to your post or a sample / similar file it will help community members come up with a solution for you
@eva218
Regards
Howard L'
chrisatsafe
  • April 27, 2020
Hi @eva218,
  • April 28, 2020
chrisatsafe wrote:
Hi @eva218,
Thanks @chrisatsafe. That solves my problem :-)
