PDF2D writer: invalid map key
  • February 27, 2020
  • 54 views
deanhowell
Forum|alt.badge.img+23
Does anyone have any idea what this means and how to fix it?
PDF2D writer: invalid map<K, T> key
It has something to do with fonts when trying to read from a local font directory. If I clear the true type font folder, I don't get the error but the output PDF is not correct.
deanhowell
  • February 27, 2020
If I change the True TYpe Font folder to directly point to c:\\windows\\fonts I get the following:
PDFWriter: Unable to successfully read the font from 'C:\\Windows\\Fonts/tahoma.ttf'. This font will not available. Internal error code was '6'
PDFWriter: Unable to successfully read the font from 'C:\\Windows\\Fonts/tahomabd.ttf'. This font will not available. Internal error code was '6'
PDFWriter: Unable to successfully read the font from 'C:\\Windows\\Fonts/tahoma_0.ttf'. This font will not available. Internal error code was '6'
PDFWriter: Unable to successfully read the font from 'C:\\Windows\\Fonts/taile.ttf'. This font will not available. Internal error code was '6'
PDFWriter: Unable to successfully read the font from 'C:\\Windows\\Fonts/taileb.ttf'. This font will not available. Internal error code was '6'
What is internal error code 6?
