PostgreSQL reader: bad_expected_access
Hello everyone,
I encountered a similar issue as the one described in the following post:
https://knowledge.safe.com/questions/95574/problem-with-postgis-reader-in-fme-2019-infinity-v.html
Basically I had an invalid date in my PostgreSQL table (no idea how it got there). It had a value of 201910-11-10 which of course is not valid whatsoever.
FME 2020 ( Build 20238 - WIN64) throws an error when you try to read this table using a Reader, a FeatureReader or an SQLExecutor/creator.
I was able to bypass this by adding a where clause upon reading (e.g. mydatefield < '2021-01-01').
I'm not looking for a solution for my problem here. I just wanted to add this to the forum so that people who encounter a similar issue know how to solve it. The FME software currently throws an error which is not really useful for debugging purposes (POSTGRES reader::bad_expected_access).
  • June 19, 2020
Thanks for sharing!
stezi
Forum|alt.badge.img+5
  • December 4, 2024
I have the same problem. Sometimes it works, sometimes not. The proposed workaround doesn’t help :(
FME Flow 2024.2 Build 24783 - win64
